When (right bottom) icon is clicked, it toggles (and collapses) the outlined blue element, works well on the front end, then this blue group in the bottom, how to hide and collapse as well, horizontally?
Not sure that it’s going to collapse horizontally. You can definitely get this done in the new responsive engine. If you can’t upgrade your RE to the new engine, then I would suggest hiding the blue round button as well and showing a new one that is center justified.
