Advanced Mapping & Routing Capabilities
I have been working diligently for months and months on my current project and have hit my first true snag. I am hoping that someone may have a solution or workaround that I have yet to discover.
My project has a “dispatch board” kind of element to it where you can select customers from certain specified criteria and add them to a map. What I would like to have is it adds the customers to the map and somehow have some form of a route optimization ability. The issue is I can not find much on the forums about how to accomplish this and not too sure which direction to head.
I am sincerely hoping that someone may have an idea! The customers that need to be routed changes based upon the service that is selected. Then, you select the customers from the results in a repeating group and add them to the map.
I greatly look forward to your ideas and thoughts!!!
TYIA!
-Eric
Hello! This is entirely possible, to the level of delivering something from one place to another two streets away, or less. Actually we could get to the meters level here but let’s leave that for another day.
First you’ll need a map element. Then a geocoding API so you can get each of the addresses’ coordinates, then you’ll need to talk to a route API, for example Mapbox and Stadia have route generating APIs you can hit them with (at least) both the coordinates (origin -> destination) then get back a route, then you’ll have to display that route in the map, usually through the draw line or draw shape feature that the map has.
Of course there are many more capabilities in this map and route and positioning world, but first focus on what you need, try to not get hypnotized by the possibilities.
You’re welcome :wink:
is the standard map element from Bubble supports draw line or draw shape feature? I was not able to find it. Do you have any suggestions? Thanks!
Any luck on implementing something like this? I’m looking to do the same.
Same here @ZeroqodeSupport can you Extended maps plugin help
Hi @chad5, thanks for your inquiry.
If it is related to the initial thread message, then yes, some of the requested features can be implemented through the Google Map Extender Plugin for Bubble.
For example:
This can be done through the “Add directions” action, which enables to add waypoints and supports the route optimization.
For more useful info, to see if certain plugin fits your project requirements, we would suggest also checking the list of available events, data calls and actions (check the docs and plugin tab in the editor), available on:
If there will be any other plugin-related questions that we can help with, please let us know :wink:
Regards,
Zeroqode Support Team
Hi @ZeroqodeSupport , I have an app where there will be a list of addresses, pickup and drop off times, I need it to be plotted on a map and then optimised. There could be dozens of addresses in a single trip and the map must be able to plot the most efficient route tacking into account location and pickup and drop-off time. Would this be possible.
