Advanced screenshot element
Does anyone know if the Advanced screenshot element will take an image of a reusable element?
Hey @darren.james7518 :wave:
You can try this plugin (I am able to get a screenshot of reusable element)…
In reusable element you will not have ID Attribute…
Instead you can give the ID to reusable element on the page
where your reusable element is displayed
For example:-
This is my reusable element
Don’t forget to add screenshot element to the page
Here is the workflow
Hope it helps :+1:
Ah fantastic thank you … I will give that a go!
