Hello,
I am working on a web app for which there is a lot of work in the back-end, especially with the integration of several APIs, whereas the front-end is quite light in terms of efforts and work.
Do you think Bubble is still suitable for my needs ?
Thanks for your insights.
It really depends on what you are planning to do at the backend. With API integration there should be no problem.
