Hi everyone,
I want to animate a word : WELCOME
But letter after letter and they come right to the center.
So I created a Text element for each letter.
But when I create a workflow “Element action - Animate” Step 1 for W, Step 2 for E and Step 3 for L, it does not work. Picture of the workflow below :
I think I have to tell at the Step 2, activate when the Step 1 is over. But I don’t remember how to do it.
Thank you
Jici
December 13, 2023, 8:04pm
2
Did you consider plugins?
And probably a lot more!
costas
December 13, 2023, 8:15pm
3
Hi Mate,
try adding pause before next action? It is a workflow action under Navigation. Hope this helps.
Hello Guys,
Thank you so much for you reply.
So Look How i created my workflow :
So I dd the Pause at the beginning of the WF for the Letter E (The letter after W). ANd I do the same thing for each letter.
So it works!
I really like the plugin so I will try with it
But I keep the Add pause !!
Than you, I learned again this night
costas
December 13, 2023, 9:31pm
5
Hi Thomas,
No worries. Glad it worked.
Yes, a plugin could possibly work too and perhaps even nicer depending on supported features.
Take care!
system
Closed
February 21, 2024, 7:44pm
6
