Is it possible to set auto animation for RG cells so they
automatically switch between each other every few seconds?
Two big banners on the top of the page:
What do you mean by âthey automatically switch between each otherâ?
Do you mean the items in it change order?
Or are you talking about 2 RGs?
Or something else?
Try using a combination of âdo every X secondsâ and âscroll to entry on repeating groupâ, check the âanimate scrollâ checkbox to make it scroll smoothly. Youâll have to use a custom state to keep track of the current scrolling position.
Hi @adamhholmes
I mean to make it as a horizontal slider, but instead of using left and right arrows or touchpad slide gestures â to set up the slider to scroll to the next RG cell automatically every few seconds.
Oh right⌠yeah in that case just use a âdo every x secondsâ workflow.
Thanks for all advices. Iâve tried several options and finally decided to go with this plugin: Repeating Group Slider Plugin | Bubble
This appears to me as the most simple solution.
