I have a repeating group that is displaying the first Thing in a list of Things (Questions). Within that, I have a radio input users can use to select an item (Answers). I also have buttons with basically the same workflows behind the scenes (e.g., Previous uses the “Show Previous” action and then animates, Next uses “Show Next”).
As you can see in this GIF, I can get the effect to work, but the data is glitchy while loading the next item (i.e., Profile icon question). Is there a way to delay the animation until the item is fully loaded?
GIF: https://1drv.ms/u/s!AjDLcHDonaB3g4c0KKoL8kjt314M4w?e=oa7vFv
I want to smoothly animate a transition between each Thing in the Questions List.
