API Calls Sending Empty JSON Body
Hello!, I am trying to create a Webhook that gets pinged for when new item is created on my Bubble app. I have tested this webhook with Postman and I get the body data. Here is my postman.
Now, here is my Bubble API Connector
And here is how I call the API in a Workflow
Regardless of how I try to parse the Payload, I get the values when sent from Postman but not from Bubble. It returns an empty JSON as shown
Please, if anyone can tell me what I am doing wrong, I would greatly appreciate it. Even when I call with static values, it also sends empty JSON.
Did you set content-type header ?
Youre missing quotes in each side of your placeholders
Thanks @tylerboodman however, adding quotes still resulted in empty paylod
Thanks @Jici Adding Content-Type = application/json header fixed the issue. :clap:
