Hi all — I’m stuck on something that seems like it should be simple, and I’ve spent a long time on it, so hoping someone can spot what I’m missing.
Setup:
• API Connector call to the Census Bureau’s ACS API (GET request, Data type set to Text)
• The call returns a nested list-of-lists, e.g.:
[[“NAME”,“B01001_001E”,“B19013_001E”,“B01002_001E”,“state”,“county”],[“Los Angeles County, California”,“9936690”,“83411”,“37.4”,“06”,“037”]]
• Clicking “Initialize call” and “Show raw data” inside the API Connector confirms this correct data comes back every time.
What I’m trying to do:
On “Page is loaded,” I have a workflow action “Create a new CensusData” (a custom data type with text/number fields). I’m trying to save one field, RawRow (text type), using:
Census ACS - API Call:item #2’s raw body text
This is meant to grab the second item in the list (the actual data row) as plain text.
The problem:
• The expression shows 0 warnings in the editor.
• When I run Preview, a new CensusData record IS created (correct timestamp), but the RawRow field — and every other field I’ve tried mapping this way — saves as completely blank.
• To rule out the record-creation mechanism itself, I set RawRow to a plain static string (“test”) with no dynamic data at all, and that DID save correctly. So the record creation and field-saving mechanism works fine — it’s specifically the API-response-to-field mapping that silently fails.
What I’ve already tried (all with 0 warnings shown, but blank results):
1. :item #2 alone
2. :item #2:item #2 (chaining a second item to get a specific value within the row)
3. 's raw body text directly on the API call
4. Changing the API Connector’s Data type from JSON to Text, then re-tried the above
5. :first item before 's raw body text
Question: Is there a known issue with how Bubble’s API Connector handles a nested list response like this in workflow field-mapping (as opposed to displaying it in a Text element)? Is there a more reliable operator/pattern I should be using to extract a single value from a nested array response into a saved database field?
Happy to share screenshots of the editor and the raw data response if helpful. Thanks in advance for any pointers!
