Api work flow optionx
Solved… … Thanks
Hmm. By any chance, have you exposed your workflow api?
No. I didn’t
Are you on a paid account? I believe API workflows only exist on paid accounts.
Yes, I am
Great. Go to Settings > API > This App Exposes an API Workflow
And click it?
Yep, once you click that checkbox, you should see the option in the Editor.
Thank you much
