I want the black text to align to the white text above, like shown in the picture above. Note that black text is dynamic data som the will vary depending on the input
Just make sure you use the same layout settings (element widths etc.) in the grey group as you have in the orange group
I checked and they are, it is all about the first text (In the picture it is marketing) the longer it gets the more it pushes the other texts to the side. But i don’t know how to fix that
Well they’re obviously not, or they be aligned the same.
Without seeing your layout settings I can’ give any specific help - but don’t forget you’ve got an extra element in the orange group compared to the grey group, so you’ll have to account for that.
