Hi guys,
I need a way for users to scan or photograph a set of documents which have sizes (dimensions). The software should then be able to identify the dimensions and calculate the square meters.
How best to achieve this in Bubble.io? Would you suggest an API to an existing software or is this doable using Bubble apps?
Thank you!
