Hey Bubble fam, Batuhan here!
AI is growing and AI generated art is storming again with FLUX release. Yes image generation cool and there is tons of job opportunities. However there exists tons of image distribitors (Dall-e, Stable Diffusion, FLUX etc.) and using correct image model on your business is crucial point. That’s why we created a prompt book and a test module for these image models. Test module created with Aicado’s integration module itself and you can embed desired AI model on your Bubble app with just an HTML element too.
Why Use the Prompt Guide?
Learn by Example: Curious how your prompts will look across different AI models? With this guide, you can check out how the same prompt looks on DALL·E, Stable Diffusion 3, and Flux. It’s like comparing art styles, all in one place!
Master Your Prompts: Not sure what makes a prompt “just right”? No worries! The guide helps you understand what tweaks work best for the kind of image you’re after, whether it’s realistic, artistic, or abstract.
Play Around with Ideas: Got a prompt in mind? Test it out! Adjust and fine-tune as much as you like, and see instant results. It’s all about experimenting and having fun with your creativity.
Explore Different AI Models: Want to know how the same prompt can give you different results across various AIs? You’ll be able to see side-by-side comparisons from DALL·E, Stable Diffusion 3, and Flux. Each model has its own vibe!
Here’s a Fun Example Between Models:
Imagine you prompt “a sunset over a futuristic city”—DALL·E might give you a sleek, high-tech skyline,
Stable Diffusion 3 could show a photorealistic scene that looks like a postcard,
and Flux might create a cool, ultra-modern interpretation that’s totally unique.
The cool part? The possibilities are endless!
What Can You Do with the Prompt Guide?
- Learn advanced techniques to make your prompts more precise.
- Play around with different prompt styles and see how little changes can make a big difference.
- Choose the best AI generator for the results you want by comparing DALL·E, Stable Diffusion 3, and Flux side by side.
- Get inspired by what others are doing, and maybe even share your own creations with the community!
Ready to jump in? Head over to Aicado’s Prompt Guide and start creating!
What is Aicado?
Aicado is your go-to platform for no-code AI solutions. Select your preferred AI model, customize it to fit your needs, and seamlessly integrate it into your business.
If you don’t know what is Aicado and how to use, visit our website our watch this video
