I’m going to take one now! If you can, try on a virtual server (I use it often just to be sure I’m not wrong sometime). Last question, are you using some kind of VPN?
I hope you’ll solve the problem soon.
Hmm… so I was curious on a VM if it would be any different, and it’s not. Has to be on the Bubble side but bubble has yet to respond. I’m not using a VPN.
@anwarsby do you have any error counts in your editor?
@lantzgould I’m not sure i understand…which “check error” do you mean…can you be more specific
Thanks a lot
@lantzgould no error indicated in my editor.
But usually when error indicated on that indicator i still can run app in version-test with no problem…but can not deploy to live.
Anwar
Yes the problem is still there for Android, can’t view in DEV mode.
The post : > http://forum.bubble.io/t/oh-no-bug-developer-version
It seem already ok now🤔
It works when I deleted the Android shortcut, and I created another one.
Day 4. Is there any chance for a reply? Multiple posts on the forum with same or similar issues. @Bubble @neerja
@lantzgould Other reports for this issue have been resolved. We recommend checking your own browser and network settings.
