Bubble interface buttons aren't working. need help!
Hi… bubble interface buttons are not working. It’s been almost 24 hours.
also, the data from the database is not loading properly. sometimes it loads and sometimes doesn’t.
Is there any update is going on or something? If not, then how can I fix that?
(image attached - buttons marked with red are not working)1
Hi, no pbm here. Reboot.
Did it many times but the problem is still there. No buttons are working on the bubble interface. I’m not able to switch pages and also the data is not loading properly.
Have you try to use an other browser?
Faced the same issue today, might be due to recent update made by bubble, for the mean time I navigated to the page I needed by editing the get request from the URL, that might just serve as alternative pending the time the issue is resolved.
Yes… something is going ON in bubble interface itself & things aren’t working properly as they should. I tried to open it in other browser(firefox) in other device and it is opening now but with different layout. let’s wait till the issue is resolved by the team.
Here the dropdowns arent filled by the Do a search for, and My Plugins and My Templates show nothing… and some more strange behaviors. People with app in live versions are complaining about searches, buttons, RGs not working.
Getting exactly the same - menu bar actions unresponsive:
page: index
edit
help
profile
Pick an element does work.
Exactly same behaviour across browsers - Chrome, Brave, Safari and Firefox.
Exactly across Bubble accounts.
issue kicked in when upgrade went live yesterday.
Strangely affecting Mac but not my Chrome book.
In the error log - there’s some kind of Object that’s getting a bad request.
Estou tendo o mesmo problema, no celular funciona normal, mas no computador estou tendo o mesmo problema que você.
limpei os dados do navegador, desinstalei navegador, instalei outro navegador, de nada adiantou.
O problema é causado por atualizações recentes feitas pela bolha, está afetando a todos, então vamos manter os dedos cruzados e aguardar a resposta.
I have the same thing
mesmo problema aqui , bubble todo bugado .
sim … funcionando bem no celular, mas não no computador.
Check out this thread: Bubble application upgrade HELP! - #9 by eve
Have y’all all filed a Bug Report? @eve said she couldn’t reproduce this issue.
Hi all,
We’re aware of something going on, but we haven’t been able to reproduce on our end yet.
So far, it seems like many of these reports are specifically about the combination of Edge + Windows. If you are experiencing problems and not using that specific combo, please file a bug report with details about your browser + operating system.
Thanks,
Allen
My interface buttons aren’t working on a Mac - and across four browsers (two freshly installed) - chrome, firefox, safari and Brave - will file bug report.
I use Windows 7 and tested in Firefox, Chrome, Opera and Samsung browser and the problems persist.
RGs not loading data, dropdowns not loading dynamic data, my tabs My Plugins and My Templates shows nothing (of course i have plugins and templates), editor locked on index page, and many more strange behaviors that started yesterday on evening (here in Brazil)… on the community of Renato Asse hundreds of people are complaining about these issues, that started after the upgrade, it seems. People are losing money with their apps that stopped working out of the blue, with app clients asking why their apps stopped work, delivery apps, etc.
Same but using windows 10.
I Received this erros in page inspector
Look at the network.
I have exactly the same problems as Landowski said
