Build a lead capture form and flow similar to thumbtack?
I’m wondering if there is a way to best build a lead generation form similar to Thumbtacks, Porch, etc? That walks you through a process and then that information can be sent to an user?
The caveat is that I want it to be a plug in/widget for users. So they can plug into their site and use for their own business?
Does anyone know if this would be possible/has been done with Bubble? Would love any advice or resources to check out.
-Alex
Example:
user clicks widget/button on website
This pops up as a flow
It is possible to build widgets in bubble…I believe another user has done for calendars. In terms of a lead generation form, yes, can do in bubble.
Do you know of any documentation or resources that could assist with building a lead generation form (like the ones mentioned above)?
This is the best place to start:
Then you can check out channels on youtube dedicated to teaching people how to use bubble; One channel I turn to a lot is linked here:
You could also decide to pay for a course…search the forum for lists of companies offering courses.
You could also look at templates and see how they built theirs…or just use the template
In terms of making it into a widget, I would search the forum using the keyword “widget”
