Hi, im trying to get the users current location using the built in feature but nothing happens.
There is any workflow configuration need for this to work?
The result is just a empty input:
Your browser is probably blocking it. Check your browsers permissions to allow geolocation
https://support.google.com/chrome/answer/142065?co=GENIE.Platform%3DDesktop&hl=en
Not the case Shawnmi6, in the same application i’m using GPSTracker plugin and is working perfectly. But i wanna sort a repeating group by users distance and the GPSTracker Plugin does not do the job.
Thanks anyway my friend.
