"colapse" on a group with a smoother way?
How can i make the “colapse” on a group with a smoother way?
I mean, the colapse action always seems like a brutal colapse, it’s possible to build some kind of “Transitions: width : 240 ease”?
Are you saying the animate collapse function is too fast?
Yes, not the “workflow animations” but the native colapse animation of the group element.
Not currently possible to customise properly but you can add an animation. So, for example, set an element’s state visibilityto yes/no type. When this element’s visibility is yes, your group that you want to animate is visible. When visibility is no, obviously not. Then, add a workflow so that when that element’s visibility is changed, it animateds with a fade in or something.
