My conditional rule for an element isn’t working.
In inspect mode, where it should say Condition 6, there’s just a gap. When I took the screenshot, conditions for this rule were met but there was no effect in my Bubble app.
Then, once the conditions of the rule are no longer met, I can see Condition 6 again in inspect mode.
Any idea what the problem is?
Could you share the expression for expression 6? That might help.
Here’s the expression.
The conditions trigger a loading graphic on the page. The data source of the repeating group is an external MySQL database. So when the first item in the repeating group is empty it means the data is still being pulled from the MySQL database, and so a loading graphic should appear.
It’s not an ideal setup but as far as I’m aware it’s the best way for me to show a loading graphic, which is tricky in Bubble.
Strangely about 6 months ago both these conditions worked. But now they don’t.
