Would anyone be able to explain if it is possible to integrate IBM Watson’s Audio to Text converter into a Bubble app? https://goo.gl/JiH794
A quick glance at the Api shows it’s very doable using the api connector. Haven’t tried it though.
Any luck?
Any luck?
