Maybe it is important to mention that I want to use this to transfer the data to a repeating group on another page and every used letter to be placed in a cell with a corresponding data from my database.
I have done everything pretty problemless but my issue is that when I have 2 or more of the same result, in the repeating group is shown only the first entry from my database.
After a lot of headbanging I’ve thought that this method with numbering the repeating letters will be the most effective.
Every ing day I see a new example why we need a “Create a list of things” action so you can generate a thing in your database per letter, and work with actual Things instead of trying to cobble together letters and numbers
Use @keith’s list shifter to create a list of numbers of the same length as the number of characters in your input.
Then in your workflow:
Trigger: When input value is changed.
Make changes to thing:
-List of numbers: format as text
—For each item: “input value:extract with regex “\w”: item#: this number. This number.”
—Delimiter: “+”
-Split by “+” (turn it back into list)
Save list in your database.
This will result in a list like this: A1 L2 P3 A4 C5 A6
Every value will be unique, so Bubble won’t remove any as duplicates, which is what is happening to you now.
When displaying the letter, just truncate to 1 to show only the letter.
I managed to get this result without a 24$ plugin.
My problem comes after that on the next page where I have 3 A’s and the corresponding data entry has to be A1(some text), A2(some other text) and A3(some other text), no matter of what position in the input the A is.
Now I get A1, A1, A1.
To be honest I don’t know if my logic is correct, I’ve tried with options sets, or with some custom states like - isUsed=true/false but every time the result is just A1, A1, A1 or A2,A2,A2 or A3,A3,A3.
I want to make a children’s book where the user types the child’s name and for every letter of the name there is a corresponding page with that letter. (like a website called Wonderbly)
So for that I want to transfer the string from the name to the next page. And if the name contains one A the page should be exactly for the first A. If there is a second A in the name I want the page to be exactly for the second A etc…
My explanation is a bit messy but I hope it is somehow understandable.
Now my problem is that I am really new to bubble and building apps (I am a game designer and have a mediocre knowledge in C#) and have no idea how to implement javascript in my app.
I think for your use case you’re going to really want to create things for every letter.
You can create an API workflow that creates them and then schedule it on a list with 0 in between and it will probably create all of them in under a second in most cases.
This worked! Just at the end the result should be printed in the JS element’s value because if it directly on a text field with ID Attribute then it is not accessible by bubble and can not extract the value or string.
