CTRL drag not working to duplicate element
Hello,
Has anyone else ran into the CTRL drag method of duplicating a page element (on windows) not working recently? If not, is there anything obvious I may be doing wrong?
Thanks
I have the same problem. And selection of several elements now works through SHIFT instead of CTRL
I have the same problem and also there are many problems in the editor for days. I hope they’ll fix soon :pray:
Yes, my cntrl and drag does not work for duplicating as well.
