Custom width problem
Hello, hope you are well. When I set the page as a custom, if the screen gets bigger, whiteness appears around it. In the old version Bubble.io, this was fixed by selecting full width, but not with the new update. When my custom size is 1440px, if my screen is set to 1500px, 30-30 whites appear.
It sounds like your page is not responsive…
What container layout are you using for the page?
Yes it is not responsive :frowning: I’m learning bubble these days. Container layout is fixed. Thank you for the response :slight_smile:
Yeah, a container layout of ‘fixed’ basically means the page is not responsive (i.e. it’s width is ‘fixed’ to the width you specify).
If you want the page to be responsive, just select any container layout other than fixed (most likely you’ll want to use a column layout for your page).
Thank you. I will try now. Have a nice day :slight_smile:
