Hi, so I’m nearly finished creating a beta version of my web app.
While the app looks good on desktop with 1200 px, when I try to use the responsive mode everything begins to break down when I try to scale down.
And so I would need to redesign the web app.
I would like to ask what is your approach to design a web app that could both satisfy desktop and mobile users.
Should I start from 360 px and scale it up or should I start from 1200 px again and constantly make changes and so that it would eventually fit mobile and desktop?
If you’re building an enterprise type of dashboard app, mainly used in an office/desktop setting. I would design for desktop > tablet. And not even bother with mobile phones. Then you can always develop a dedicated mobile app, and be cheeky enough to charge more for it (e.g. higher tier plans get access to mobile app).
If you’re building a more everyday type of app, e.g. a sneaker listing app or what have you. I would go Mobile > Tablet > Desktop. Especially if your target audience are younger, a lot of youngsters today access internet on their pocket machines, some doesn’t even have desktop/laptops. * gasp *
My app would be mostly for distance education and targets 6-20, so I guess mobile first then to desktop.
I want to ask if you design it from 360px how do you scale it up since when I use responsive mode from 360 px to like 1200px the groups and elements would not move and it would just widen the width. I would also not be able to move around the groups since my size is limited to only 360 px.
The responsive engine is a beast on its own. I spent hours watching videos and doing trial and error before I was able to make sense of it. It’s hard to wrap up in a forum post how it works and all the quirks. The best suggestion I can give is, watch videos and do trial and error, unfortunately.
For the specific case you mention, have a look at wrap to previous line.
Thanks for the tip, it worked and it wraps to the previous line, but I would need to see some videos to explain how the responsive functionality works.
