Difference between "Do a search for" and ":filtered"
In a repeating group, in the data source, I have noticed that I can enter the same constraints either in the “Do a search for” or in “:filtered”? Are there any implications in performance depending where I add the constraints, given that I can manipulate the RG the same with both options? I experimented a bit and my app crashed when I entered my constraints in the “:filtered” section
Thanks in advance!
“Do a search for” happens on the server-side and “Filtered by” happens on the client-side.
So "DO search for " is must faster as compared to “Filtered by”
Ankur@ Nocodetalks
Helping Bubble Devs to build No-Code Products. Follow me on Twitter
Thanks for the clear answer :ok_hand:
