Display order data for each Clients
If I want to display data such as attached files, how can I configure it?
On the right add new Repeating Group “A” - same datasource as your left repeating group but add :each item's Client:unique elements
Inside the cell of RG A add a Repeating Group “B” with the same datasource as your left repeating group but with an additional constraint Client = Current cell's Client
Also inside the cell of RG A below RG B is your row to say “Current cell's Client's Name’s Total” and another text element with the same datasource as RG B but add :each item's price:sum
Thanks your reply.
Now, I tried to set your plan,
But setting the “each item’s client:unigue ekement” is occured error(picture).
Do you know the resason?
make RG A datatype “text”. I thought Client was its own datatype
A table like this will be created. What could be the cause?
Something not setup right, can you screenshot the datasource of RG A and RG B and the text element showing the letters/numbers :blush:
Or if you go into the app settings you can make it “anyone can edit” and share the link to the editor here
Appreciate your kindness.
This URL is test appli.
https://bubble.io/page?id=testikari&tab=tabs-1&name=index
Feel free to make any changes.
Best regurd.
Check it now :smiling_face:
also, item should also be another datatype just like client :face_with_hand_over_mouth:
wonderful. This is what I wanted to achieve.
I’m sorry for taking so much time away from you.
Thank you very much. :pray:
I’ll do a little more research on what was achieved.
