Do when (need help)
Hi guys, This is my problem. I have a db called checkout. I want to go from first item to last item compating the creation date and the current day. if the result is 30 days I want to send and email. I want to send this email every time the condition happens. Tks in advance.
Have a look at “Schedule an API Workflow on a List”.
That should enable you to do what you want.
Tks Nigel. I will
Hi Nigel, sorry for bothering you. I can´t get the date comparision…
. Any idea?
You haven’t finished the comparison. Basically, here’s what you’ve said:
  • When this checkout’s creation date plus 30 days
I think you want to say:
  • When (current date) is greater than or equal to (this checkout’s creation date plus 30 days)
Am I understanding correctly?
Yes. I think I got it. Do you know how often is this recurring event running in order to test if the email was sent?
