Drag and Drop Does not Work [Bug]
I need forums help as I have not received any response yet from support since monday. Drag and drop plugin from Bubbles dev tem does not work or I dont understand smt. I am currently building todo app like Trello. It is a board with columns and draggable elements. The place everything stop working is when I am placing drag/drop element inside repeating grup. It is not simply shown. Check the video below.
I just experienced this with another client. Did’t realize it was a Bubble bug. I hope they fix it for you and don’t take 2 weeks to fix it. :sweat_smile: Definitely looks like a bug to me, it shouldn’t disappear like that. It seems to only impact when you are building something new and not what is already created. That’s probably why they haven’t seen a bunch of bugs because the one I created still works. But trying to create a new one doesn’t work.
@fede.bubble Is the team working on this? Some will be stuck not being able to use this plugin. I just tested it too.
checking with the team, brb
Following up here, the team found a ticket you submitted today. While they try to get back to users asap, in most cases it takes more than a few hours. Do you have the number of the ticket you submitted on Monday so we can investigate what happened there?
In terms of drag & drop being broken, issue was escalated to the team so they’ll triage this soon
Hi. Related ticket was created on monday as repeating group was not shown up at all. Have checked recently - nothing changed, still doesn not work.
