Hi
I’m very interested by this features.
Your back is not open anymore, i know it’s done long time ago but if you still have this back, it’ll be so great.
Or if there is any update about this feauture…
Thanks a lot in advance
Hi
You can achieve this using this map plugin from Skillum:
Demo:
This Plugin will allow you to drop a pin (it’s actually a flag
) on a Google map, then you can use the “Calculate formula” then “coordinates to address” then you can choose to dynamically get the latitude and longitude information from the map.
Good luck!
