[Forum] Marking posts are "solutions"
Hello,
We’re just added the ability for the original poster of a question/thread to mark a response as the “solution”. Once this checkbox is clicked, the thread will have a check next to it (no need for ‘SOLVED’ any more), and it’ll be easier to find the answers.
Please try to use this as much as you can when you have a good answer, it’ll help make the forum a more organized resource.
This is the “solution”
Any way to have one additional checkbox for “Helpful”? There could be multiple helpful posts that aren’t a solution.
The discourse plugin doesn’t let us to that unfortunately.
No more [SOLVED]? ;( hehe
Organized, Yes pls!
