Freelancer to help implement QR codes, affiliate system
I need help implementing the following use case.
We publish a print catalog for our agents and each agent has a unique QR code sticker on the cover of the catalog. The catalog features yacht listings in which each yacht has its unique qr code as well. The yacht listings are managed in a bubble application.
The idea is that a reader of the magazine scans the qr code of the agent, is then logged in with the agents credentials and when the reader scans the QR code of a yacht, is then brought to the yacht page with the agents credentials. When the reader makes an inquiry the inquiry must be logged in a way that we know from which agent (catalog) the inquiry is coming from.
Need help to implement a elegant solution. We can only customize the catalog QR code, not the QR code of each yacht for each agent.
Hi Rico,
This is well within my area of expertise and I would be able help you out
You can reach me on [email protected]
Best Wishes,
Andrew
Hello @rico
We’ll be glad to help you out with this. Check your PM please and feel free to leave your request on our website, or just email us at [email protected] .
Regards EzCode Team !
Hi @rico,
We’ve just launched the integrated QR scanner (Nativator.io), for your concept, you could usea QR code generator plugin which will encode a thing’s link.
So the link will open a page where you will require users to login.
Hope it helps.
Sam
Thank you Sam, this is very helpful. I’ll look into it and will most likely go ahead with it. need to dust off the application again :wink:
