Generate Json Web Token problem, please help me to understand it
Hello, please i need some help to understand what i am doing wrong
I am trying to generate JWT for an adobe API, with the RSA Private Key through Plugin Json Web Token
but i get an error when i try to generate:
" {“library”:“PEM routines”,“function”:“get_header_and_data”,“reason”:“bad end line”,“code”:“ERR_OSSL_PEM_BAD_END_LINE”}"
i have taken all screens of flow and the RSA certificate and payload that i am adding to JWT Generate and the flow
my RSA Private Key:
-----BEGIN RSA PRIVATE KEY-----
MIIEogIBAAKCAQEAoO8XTylCYKHI8XA8khqe55tUZYDuH2mUUw3/JXHBsFFJRBSH
qfpa3qfng8UkUlICwxkVzGnh+qsjzXuLaiHb2kgRZ7xl3KJ2cqO+ZYQy/lxpwVf0
yYBTRaQVx
rBDjiEk1GvPBrskpYwPhtGH5zKFw9DsivL0l8LAZbtnECECMECo=
-----END RSA PRIVATE KEY-----
payload is :
{“exp”:1664820686,“iss”:“54548ADFJ4D1F43635C3F@AdobeOrg”}
the RSA is benign and copied exactly as it comes from adobe, but I
just deleted the middle of the key for test purposes and the payload also deleted some information
Please could you give me a hand,
Thanks you in advice
Best Regards
