Hello,
Looks like the Searchbox may have a bug. When typing a city in and then selecting a city/location/address option from the list of options provided, the data appears in the Searchbox as an input value, however, when trying to create a new thing using this Searchbox’s value, no Location data is created in the database. I did find that in my case, deleting the “USA” in say “Chicago, IL, USA” will then create the data or if you type in a couple of spaces after the “USA” it will save the data.
If it’s not a bug, does anyone have a workaround or alternative method?
Thanks
