I used a group focus for a menu option but when I try to pick the reference element which is an icon in a repeating group nothing comes up. Or it’s not possible to use a group focus and reference it to an element in a repeating group?
@stacyarnette when added to a page, it’s not possible to reference a Group Focus to a Repeating Group cell.
That being said it is possible to achieve what you want to do by creating a reusable element that you place into the RG cell. Inside the newly created RE, create your Group Focus. Then, create a workflow within the RE that opens the Group Focus whenever the RE is clicked.
Hope that helps
