Have 0 x offsets but element is offset right
Hi
If you check the screenshot below, I cannot figure out why my chart element is offset to the right when the element and all parent groups have 0 x offsets set.
Any suggestions will be appreciated.
Thanks.
Hey @marksrunge :wave:
That certainly is frustrating. I’m assuming you are on the old responsive engine?
It can be very tricky to find.
The first thing I would check is this overlapping element.
Let me know if that helps. :man_shrugging:t2:
Many thanks for your suggestion.
Unfortunately, that didn’t fix the problem but your “overlapping” suggestion is 99% likely to be the culprit.
Such a shame we can’t drag/drop in the element tree.
This shows that your suggestion is likely to be correct.
Maybe try moving this out of the way so it doesn’t overlap either. I know this is the tooltip probably, but I would give it a shot anyways. :man_shrugging:t2:
