I am having a problem with the physics of a buttom.
in the green part it is clickable, but in the red part it isnt. Why does that happen?, and when I put that buttom outside the group it doesn’t happen
When you put it inside a group, the group’s height might be smaller than the button, therefore, it is leaking outside the group and another group might be blocking it. See the scenario below: bottom half of the button is not clickable, because there is a group blocking it.
The button is bigger than the group:
There is a group in front of the bottom half of the button:
When I move the button outside the group, it works, because it is treated as a separate element in the layout of the parent.
I hope this gives you some idea.
@Huseyin from Flusk | Discover the #1 Security and Monitoring Tool for Bubble
