Help appreciated: Stay logged in issue
I created a ‘stay logged in’ checkbox to enable the user to stay logged in and prevent automatic log out. It is still having issues. I would appreciate it if someone could take a look at the attached snapshot and provide advice if it is correct.
Stay logged in workflow
Can you put a text on your page and give it the Text ‘Checkbox stay logged in is checked’ and see if it says yes when you check it and no if it is unchecked?
It doesn’t work that way. Thanks for your response.
The default ‘yes’ and ‘no’ for stay logged in in the workflow component ‘Log user in’ doesn’t seem to work. I used this tutorial: How to Keep Users Logged In to Your App (so they don't get automatically logged out) - YouTube
Screen Shot 2022-01-28 at 9.26.49 AM
Screen Shot 2022-01-28 at 9.27.09 AM
Screen Shot 2022-01-28 at 9.27.14 AM
