Hi all i am trying to mimic product hunt for the airdev bootcamp exercise. I have been battling how users when creating a product can add their own tags then save those tags in the data base individually. Right now i have made it where users add tags and it pull show in a repeating group what tags they have inputted then when its all filled out and they hit submit it saves the repeating group. But it saves everything in the repeating group as one instead of individual tags. Is there a way to make it save each input as its own.?
Hi! Use the :add list operator instead of the :add operator and you should be good to go
thank you so much i cant believe i didnt do that
No worries, that happens to all of us ![]()
Glad you got the solution
