I am using the plugin search & autocorrect for a more accurate search, I want the search to start only once the enter key is pressed, and to be displayed in a new page. I have tried several ways and it doesn’t work, any suggestions?
Hi @less61tunas
You can try like this
Don’t set data source of Repeating group
Set it when the input value is changed (Just right click on input the click start/edit workflow)
Screenshot 2022-08-22 at 10.43.26
Thanks a thousand, that’s what I wanted it to do, it works!!!
