Help sorting repeating group
Hey guys,
Could really use your help if you know how to do this.
I’d like to sort a repeating group by first showing entries in the future (with those closest to current date/time) appearing first), and once there are no more future entries, I’d like it to show past entries (with those closest to current/date appearing first). The image below explains how I’d like it to be sorted.
Does anyone who how to achieve this? Thanks
Try the following:
Search For Item’s (Filtered by creation date > current date and sorted by creation date / descending = no) date
MERGED WIH
Search For Item’s (Filtered by creation date < current date and sorted by creation date / descending = yes) date
Hope this works for you,
Daniel
Hugely helpful, thanks Daniel!
I have a similar question, slightly different sort. I have a list of items that need to be displayed in ascending order of the field “Sort order” - have not been able to figure this out. Any help would be much appreciated, thanks!!
What data type is the Sort Order field? If it’s a number field, just to sorted by Sort Order:descending = no
