In that case, you may find Web Scraping APIs to be helpful, as they can pull data from external sources/websites and you can take just what you need (like the name, description, website url etc)
Here are a list of websites that provide web scraping as a service:
Some of these services can provide the data in JSON format, meaning you’ll need to set up Bubble’s API connector for your app to communicate with these services, this will be a more automated way of doing it but will need technical knowledge to set it up.
But the data can also be provided in other formats like in CSV documents, which is good because Bubble does allow you to import CSV files, however, this method is not as automated but it can save lots of time as you are able to import information in bulk rather than one-by-one.
I hope you found this to be helpful
