I want to have a dynamic expression where I am searching the database for a users first name and last name but have it only displays the initials of the first and last name. any ideas?
Can you mark it as the solution please? it helps others find the answer to things.
It seems to be only displaying a users first initial
Did you set it up the exact way I showed in the screenshot? i.e. with the append function?
Yeah
You don’t need to append, just put the first dynamic expression and then add the second dynamic expression without a space
wont let me
It does.
Don’t click ‘more’ after the expression, put the cursor just after the expression and wait until you see the blue insert dynamic data pop up, click on that and then build the expression
Ok, that worked. Thanks @equibodyapp and @paul29
I just need to figure out how to force them to be capital letters (some users don’t enter their name is capitals on sign up)
There is an uppercase operator
All done! Thanks
