Help with building a cashflow
Hi There, I’m trying to build a simple cashflow app for my family, i have managed to create current bank balance entry, monthly income and current expenses and pullled them into a repeaing group. now i need to create a formula that adds the the bank balance and add/subtracts the monthly incomes and expenses as it goes down the list ? I’m really struggling to use the available calculations to achieve this? can anybody help or suggest a plug in? the formula will be as follows : line one = balance + current cell ledger expenses
: line two = line one total + current cell ledger expenses
the problem im having is the repeating group copies the formula so i cant have each line add the above line?
To extract calculations made inside a repeating group you will need the RepeatingGroup Tools (BDK) plugin.
Thanks Robert ll give it a try! Appreciate your response
