I am attempting to create an app for mobile and not a website. Can’t seem to change the layout, how do you do this?
Hey welcome to Bubble!
The first thing would be to make sure the “Make this element fixed-width” box is checked for the main page. Then the page will be responsive and you can make it fit any size screen.
What else do you need help with specifically?
Hope this is helpful.
Worth pointing out: Bubble will not generate native apps, you can only generate web apps that can be wrapped to create a hybrid app. If you aren’t careful, it’s very easy to get rejected by Apple by taking this approach.
