pieter
March 3, 2017, 10:28am
1
Hi there,
I would appreciate if someone could help me with connecting to the API below in our Bubble App:
API Docs: https://www.didww.com/api/
App: https://bubble.io/page?name=index&id=virtual-landlines&tab=tabs-5
I can’t seem to get past the auth_string element to authenticate. According to the provider it needs to be converted to a SHA1 string using the “username” and “key”. We have both however can’t connect to https://api.didww.com/api2/?wsdl
Once again appreciate any assistance in this regard.
Regards,
Pieter
pieter
March 13, 2017, 10:37am
2
Hi Guys,
Any assistance with this will be appreciated. Is there maybe some partner that could assist at a cost?
Regards,
Pieter
this is an api that uses soap protocol whereas bubble uses rest so i dont think it will work
mishav
March 14, 2017, 10:29am
4
Hi @pieter ,
I haven’t tried any SOAP APIs from Bubble, but @gcmcnutt seemed to get somewhere:
Well, we are very close with bubble making api calls to some soap based web services. For now, I think I’ve run into a blocker where I can’t insert dynamic data (e.g. an input field) into the soap template. It seems that the entire template is replaced.
This does work when the template is json, however.
Here is a screen grab of the issue in the editor:
[image]
If I click on ‘insert dynamic data’ here, the entire template is replaced.
Please let me know if this is something you can correc…
