Help with Dynamic Choices in Dropdown
I have two data types:
  1. “User”, with fileds like name, email and company_name
  2. “Location”, with fields like location_name and company_name
I need to create a “location_name” dropdown but only show options related to the company the user works on (based on the “User” data type relationship).
Right now I am only able to show all locations, without the constraints with the following:
Any tips? Thanks!
In 10 words, in your “Choices source” add a search constraint that uses the User attributes as a filter.
You on a word diet, @lindsay_knowcode? :slight_smile:
To add a bit more clarity, add a constraint to your Search for Locations where company_name = Current user's company_name. That should do the trick.
Best…
Mike
legend! Thank you!
:rofl: @mikeloc Yes I should have put in a bit more effort on that one. :upside_down_face:
