I have two drop down menus but the problem is when you select the top one and the results from the top one “from” field drop OVER the ‘to’ field or the 2nd drop down the user can’t select an entry properly on mobile because it focuses their cursor on the 2nd drop down input instead of selecting the appropriate option from drop down 1.
Without spreading apart the inputs, which doesn’t look so good, is there a way around this?
