I have two pages with the same herobox and the same settings (copied). One expands all the way across the screen, the other doesn’t.
https://app.rentbridge.ca/version-test/?debug_mode=true Here is inspectable version of the one not expanding across. It will re-direct you to the other page automatically since you won’t be logged in, so then you can see the one that is wide.
Any idea what might be preventing it from going all the way across?
