Hey guys i was using a custom script and this error showed up
This occurs only when i am trying to use “current page items” twice.
if i were to delete one of the lines containing “current page items” it works fantastic
i am using the toolbar plugin.
Any help would be appreciated. Peace :crossed_fingers:
I appreciate this doesn’t answer your question but why are you using Toolbox for what is a very simple calculation? Can’t
you just use Display data in group where the group is of type number and calculate the price in that expression? Or, even better, set the data source of that group to your expression.
One of the dynamic values is empty. So, the evaluation only finds the “;” without a value (empty), and that’s what the error says.
Double-check the dynamic values, as at least one of them is empty.
I agree with @georgecollier; you don’t need Toolbox for this.
No because bubble doesn’t follow bodmas rules and neither does it support parenthesis that’s why I need toolbar
arbytrary text + converted to number is one of the usual workarounds, not nice but it works
You haven’t done your research then, because if you go to Settings → Versions → Experimental features in your editor, you can enable parentheses right there. Otherwise, expressions work left to right and you can still build any expression like that.
its way too clunky i tried to do it but auto parenthesis gets it wrong everytime
i did check but no all values are correctly present
No, it works well - you’re doing it wrong! No point using Bubble if you won’t use the expression editor…
