Hovering an element changes the properties of another element
Hello!
Is it possible to change the properties of an element when another element is hovered?
My example would be changing the zoom of a map when an element is hovered. What about changing a custom state when an element is hovered.
This pretty much is a mixture of workflow actions and conditional actions. I know bubble can handle both things, but it appears that these two functionalities cant be joined. Am I wrong?
Thanks
Hey @nico.dicagno :wave:
That certainly is tricky! :blush:
There are a few different ways to do this. I hope this example can at least show you some examples on how it could work. The key is to use a group. Check it out:
Editor: Test805421 | Bubble Editor
Preview: https://test805421.bubbleapps.io/version-test/hover_an_element_to_chang?debug_mode=true
Hope that helps! :blush:
@j805 www.NoCodeMinute.com
